wlan adapter for existing none-wlan speakers
    Hi Q
    Bluesound is a closed distribution system designed to work with other Bluesound/BluOS enabled products only. That being said, check out the PULSE or PULSE MINI at your Authorised Bluesound Dealer to see how easy it is to plug in a second Bluesound Player and instantly get music in the next room with our distributed music indexing system.
    Comment actions Permalink
