    Avatar
    Aaron W.
    Hi Kevin,
    For your Windows share, have you read our article regarding some computer configurations(firewall, anti-virus) that might hinder the shares to be connected: https://support.bluesound.com/hc/en-us/sections/200101056-Computer-Configurations
    Alterations from default sharing settings may have changed in Under "Change Advanced Sharing Settings"
    In Windows 10, Anti-Virus programs can change these sharing settings from default settings.
    For the Current Profile:
    - Turn On Network Discovery
    - Turn On file and printer sharing
    - Allow windows to manage homegroup connections
    For All Networks
    - Turn ON sharing so anyone with network access can read and write files in the Public Folders
    - Use 128-bit encryption to help protect file sharing connections
    - Turn OFF password protected sharing (This has been changed to ON by some antivirus programs)
    These options can be found from the Control Panel - Network and Sharing Center - Change Advanced Sharing Settings
    Comment actions Permalink
