Sort order tags?
AnsweredI see multiple request for this feature over multiple years. What is the current status / position on adding sort order tags?
Just got my Node last weekend and I'm overall happy with it. Learning the quirks however has been painful.
For instance one of the things that aggravated my efforts to figure the sort order tag issue out is that the settings/library/re-index does some sort of optimized reindex. Finally found the diagnostic / reindex button that clearly states it deletes the index and starts from scratch. Having this clearly explained up front would have saved me hours of time.
Thank you for reaching out and sharing your feature request with us. We appreciate your feedback and value your input as it helps us enhance our products.
I want to assure you that I have forwarded your suggestion to our dedicated teams in both quality assurance and development for careful consideration in future updates. We truly appreciate your support and look forward to continually improving our product to better meet your expectations.
Thanks for #LivingHiFi -
Just adding my thumbs up for this in the hope that a reply will make it more visible to those in charge....
It's quite possible that it's my comments you've seen asking for this. Would be a massive improvement.
