Research via deezer (on BluOS) does not load
AnsweredHello,
For few weeks i can't use the search option on deezer via the BluOS app to use my bluesound node.
I have the loading circle on the center of the screen and nothing works. I have uninstalled the app, have the latest version, wifi is working just fine.. I just cant understand...
Can you help me? Thank you
Not staff but a user…
Deleting the App won’t help but I would remove the login credentials for Deezer in the BluOS App, reboot the Node then add Deezer again into Music services.
In the BluOS App please select Settings, Diagnostics, Reboot to reboot.
any help, bluesound staff please?
thank you, i'll try this tomorrow...
Its quite boring to use the bluetooth when you purchase 500€ streamer to avoid this...0
