Volume Levels
Hello. I've noticed recently, perhaps since the upgrade, that my Node (original) sound volume is considerably lower with Apple Lossless files then with my older MP3 files. Is this typical? I have it connected via optical to my Cambridge Audio integrated.
Hi Joe
We have not made any changes here. Do you have Replay Gain turned on or off in your Audio settings.
Check that out and if you are still having issues, please select Send Support Request from the Help Menu in the App
Comment actions
