Bluesound Node firmware upgrade stalled
  • Avatar
    Ole Lennert
    It has now been stuck for more than 2 hours. I'm pretty sure that isn't supposed to happen.
    BTW, my Node is on ethernet directly to the built-in switch in my router. So no wireless. Internet access from my computer is working as it usually is, so I don't believe it is a connectivity issue on my end.
    Comment actions Permalink
