External DAC's not able to decode sound format from TuneIn (danish regional radio channels)
    HI Karsten
    No changes were made to DSP. It is more likely something changed in the Radio Stream. Check and see if an alternate stream is available. Here's how; https://support.bluos.net/hc/en-us/articles/360000261928
  • K.M. Chr
    Same result I'm afraid with thoose specifik radio channels. But no worries I will just listen to them directly from my Node X :)
    Thank you and have a nice day.
    Karsten
  • K.M. Chr
    I solved it by changing to coaxial from optical in another context (needed more bandwith to play flac 24bit/192kHz via Tidal Connect).
    Karsten
