Volume Sync for linked players
    Avatar
    Aaron W.
    Hi Craig,
    Thank you for reaching out to us through the support ticket, we'll respond to you to resolve the issue.
    Comment actions Permalink
  • Avatar
    Stefan Mehre
    Hi,
    this is something I am also thinking would be great. If somebody wants different volume values it should be possible to change them, but first with grouping I think it would be great that the volume gets synced. Maybe best would be if you could setup this syncing on all players, so the user can choose if a player gets synced or not.
    Is there something in progress?
  • Hi Stefan
    A lot has changed since this post including a stereo pairing wizard which will level the volume in Fixed Groups; https://support1.bluesound.com/hc/en-us/articles/230412107
    In regular grouping, volume syncronisation is not a good thing and would cause more problems than you think as not all products treat volume the same way. A POWERNODE in my living room sounds a lot different than a FLEX in my bathroom at 50% volume...
