Using Spotify Connect with Bluesound behind Airport Express
My Bluesound Vault is connected to an Apple Airport Express, and it works just fine for Tidal - however I cannot see the Bluesound device in Spotify. It seems as if Bluesound needs to be wired to the router directly for Spotify to see it; as if Spotify can't see behind an Airport Express.
I hope someone could confirm this, or better yet, provide an alternative way to make it work as it's physically impossible for me to connect my Bluesound Vault to my router directly.
Hello Pablo,
Is your Airport Express working as a Bridge/Access Point, or is it working like a router, and handing out it's own IP addresses?
Also, try using both the Spotify Desktop and Mobile Apps, and check if either makes a connection. If one Spotify app connects, then all the Spotify apps might learn how to get to your Player.
Comment actions
