Vault 2 stuck in upgrade
    Hi Craig,
    We've seen that you posted this question to the Bluesound Support Crew as well!
    Our Support Crew is currently assisting you, please reply to the emails from your support ticket.
    Comment actions Permalink
  • Avatar
    Craig Hargreaves
    Thanks
    Bluesound Support sorted out, needed to upgrade using a USB.
    Once done then all back to normal.
    Not sure if the LED is actually a button on the Vault2  though!
    thanks again for the prompt reply, didn't realise community was also Bluesound
    Craig
