Pulse Mini - Bluetooth connection without Wifi
4 comments
    Avatar
    Kyle F. - BluOS Support Specialist
    HI Ivan,
    Yes when you have the player in solid green(hotspot mode) you can connect to it with your phone and play music via Bluetooth, no WiFi network needed.
    Comment actions Permalink
  • Hi Ivan,
    Please see this article for more info on this - https://support.bluesound.com/hc/en-us/articles/200529796-Connecting-Establishing-Bluetooth-with-Bluesound
    The default is manual mode however you can set this to automatic which will play your source when you select it, please see the link for more info.
    Thanks for #LivingHiFi!
  • Avatar
    Ivan Trachta
    Hi Kyle,
    thank you for your answer. I have checked mentioned article but didn't find an answer to my question in it. I would like to know whether I can take my Pulse Mini outside my Wifi range and play music via Bluetooth when player is not connected to any Wifi network.
  • Avatar
    S. Beryl
    Hi.  I have my Bluesound Pulse Flex in sold green / hotspot mode, and have connected to it with my Windows 10 laptop.  It says it's connected, and I set the "Pulse Flex E067 Stereo" in Sound properties to Default Playback Device, but I can't get any sound out of the speaker.  Can you help please?
