Can configure Synology drive but it does not show in the Navigation drawer
5 comments
  • Avatar
    Jeroen Top
    I re-indexed and it said it took care of 14609 songs.
    If I go to configure player -> diagnostics, it says Total songs: 0
    I am lost
    Comment actions Permalink
  • Hi Jeroen,
    If the issue is still persisting please e-mail us at support@bluesound.com and we can reach out and help further.
  • Avatar
    Christophe Vanderschueren
    I have the same problem, do you have an answer from BlueSound ?
  • Avatar
    Witold Kowal
  • Avatar
    olivier manzoni
    Hi, I have the same problem with an Apple Time Capsule, I assume it is a very similar problem. help will be welcome. I have reindexed the network share library for good measure. Did not help.
    Thanks
    Oli
