Connecting Bluseound Vault 2 to an Arcam D33 DAC
I apologise if this is a silly question but I am new to HiFi really.
I connected a Digital Audio Coax (audio quest) from the Coax Out terminal at the back of the Bluesound Vaulut 2 into the DAC (Arcam D33) Coax Terminal. The Dac is then connected to the Amplfier. I had all correct selctions made on the Dac and AMP but Unfortunately I get no sound when I play the Vault? Would you know why? When I attach my CD to the DAC in a similar way with the same cable its all ok and I can hear CDs beautfiully. Thank you
Hi John,
Thank you for opening a support ticket with us. We'll work with you to resolve the issue with your DAC through your support ticket.
Comment actions
