Bluesound Node 2i with subwoofer
Followed by 2 people
    Bjørn Ulvik
    Sub should be connected to the equipment that's controlling the volume.
    When output level is fixed, the sub out will be at maximum volume.
  • shay
    Thans,but the pre Amp dont have sub out...
  • Andrew Dixon
    Is your sub powered with a high level input? If that's a yes then you maybe don't need a sub out on your amp, but could go from the same outputs that go to your speakers (I know this applies to REL subs but don't know about other brands)
