    Avatar
    Peter Gray
    Hi Pablo,
    At the risk of upsetting anyone, I have Power Node + Duo in one room and Two Pulses in another.
    The sound in both rooms is excellent.
    The Two Pulses are better in my opinion unless you like the walls moving with the bass from Duo..
    I do..
    Regards
    Peter
    Comment actions Permalink
  • Avatar
    Peter Gray
    One other point is that the pulses are easy to move to different rooms, garden etc, PowerNode + Duo is for setting up and leaving alone.
    I bought nice stands for the speakers but later moved them onto a bookshelf and used these stands for the Pulses.. I can recommend that too.
    Regards
    Peter
