Tidal doesn't work Error:forbidden
9 comments
    Avatar
    Iain McGinley
    Bluesound support got back to me to say that they can also replicate the error in the lab.They think it is a tidal server error and are investigating further
    Comment actions Permalink
  • Avatar
    Helene Krøjer Holst
    I have the exact same problem in Denmark on my node.
    Tidal gives error fobidden and a 8 - 10 digit failure code on all playlists and Music searches. Tidal Works ok on IPad and IPhone but NOT on the Node. Reebooting the IPad and Node do NOT solve the problem.
  • Avatar
    Andreas Brathetland
    Having the same problem with TIDAL/WiMP here in Norway. Also tried to reboot my node and sign in and out of the music services. Didn't work.
  • Avatar
    Ken Olsen
    I have the same issue in Denmark on my Bluesound Pulse. Worked like a charm previously but suddenly I have these problems. Have tried everything and have now submitted a request for help to the Bluesound Team
  • Avatar
    Iain McGinley
    HiJust logged a support call for the same error.Getting it here in Scotland on my Node
  • Avatar
    James Pollock
    Also here in the UK. Intermittent fault, managed to play one track but then it stopped with the same errors as described here.
  • Avatar
    Sjur Mjanger
    I also have this problem. Both with wimp and with tidal as i now have two accounts. However, it seems to only be like this with spesific songs. for example, i can play track 1 on london grammars "if you wait", but i cannot play track 2. i've now added tidal on my bluesound node and will further try to remove the wimp account from it and see if that helps.
  • Avatar
    Inge Aas
    Same problem here. Norway. Only today in Tidal/Wimp. Spotity works normal.
  • Avatar
    conor maguire
    Having the same issue with accessing tidal music from my Bluesound Vault. Any fix???
