Grouping a Node with external DAC and Pulse
    Avatar
    Jesse J.
    Hello Johan,
    When you group players, they act as if they are the same player, playing the same content in sync.
    You will have volume controls for each player in the app, and one volume control to raise the volume of the group.
    Grouping a Node (w/DAC) and a Pulse should work just fine.
    Comment actions Permalink
