Ripping problems
7 comments
    Hi Torsten
    Please contact us at support@bluesound.com or by selecting Send Support Request in the App and we will review and make a recommendation for you. As you can see from Paul we were able to get him back up and running.
    We do here about problems with the Optical Drive as it is the only moving part in our Bluesound Players but are happy to review and resolve via warranty.
    Thanks for #LivingHiFi
    Comment actions Permalink
  • Avatar
    Paul Pottage
    Greetings from Australia
    There is obviously a significant issue with the CD mechanisms initially installed into the K3 and K4 serial number vaults. Took delivery of one before XMas 2014 and ripped about 100 CDs then as per Torsten about 1 in 5 was accepted. Returned unit after advice from Support. Brand new K4 serial, went faultlessly for about 60 CDs then the CD transport failed completely and sounded like it was not even spinning the CD. Support advice conceded "We've reviewed your case and there seem to be a hardware issue with your Vault " Returned this one to the dealer, who remembered my name this time, to be greeted with "Ahh yes we've got one in from last week they are putting in Teac units, will fix all the problems" No mention of this from Support which is a pity because I was going to ask for my money back but got the confidence - from the local dealer- to hang in. Great units Bluesound but I would have appreciated some forthright advice on what is a pretty fatal, and obviously widespread, problem pp
  • Avatar
    Torsten
    Hey Paul, thanks for tuning in! I will check the serial number. There is "wstarz" with similar problems (K38V500W02514). I think i have to contact my local dealer as well. Greetz from Germany
  • Avatar
    Arthur Pilla
    Hi All,
    I also had the same problem reading CDs after the first 50 or so. Bluesound identified the problem as hardware and my dealer instantly responded with a replacement Vault. However my mew Vault still has a K4 serial number. Should I anticipate needing another replacement?
    Otherwise the Bluesound Vault is performing at a very high audiophile level. I am using a high end optical cable and I have replaced the wall wart with an audiophile grade power supply.
    Arthur
  • Hi Arthur
    Glad we were able to get it straightened away. If you have any further issues please feel free to let us know
  • Avatar
    Tilman Burggraef
    Dear all,
    since a few days ripping of my Vault2 doesn`t work anymore. Problems started with the CD optical drive making a terrible noise. I checked all software options described on this page but it didn't help so I fear the drive is damaged. I did not use it too often /I ripped between 100 and 150 CD`s roughly but used the vault more as an internet connection. AsI fear the drive is damaged - what should I do? Serial Nr. of my Vault2 is K59V2B03329.
    Best regards
    Tilman
  • Avatar
    Hello Tilman,
    This post was originally regarding the Gen 1 model of the VAULT, while it looks like you've got a VAULT 2, so the issue you are seeing is likely different.
    In any case, I see you've got a support request open; a member of our support crew will be in touch.
