No audio over hdmi (eArc) n130
Answeredaudio dips occur when I connect to the eARC port on my tv . Got help from samsung remote service , and they reinstalled the software on the hdmi connectors so they should be working properly. So i guess it's the fault of the node . Any tips?
HI Magnus
Can you please select Settings, Send Support Request so our Support Crew can review the NODE log file and hopefully finish this off for you? Once they have the log file and review it they will reach out via e-mail. We are experiencing a high volume of calls right now so may be a day or two. Thanks
Will do , thanks
