Entire Library not Syncing to BluOs
Followed by 3 people
    Brian
    Lossless
    Another Bluesound user here. Best practice for large music libraries is to use a network share connected via ethernet to the network. I've got over 2TB of music files on network attached storage.
    https://support1.bluesound.com/hc/en-us/articles/203904628-How-do-I-connect-music-on-my-NAS-PC-or-iTunes-Shared-Music-to-Bluesound-
  • Bob Heuvel
    NAS is also what I use. You only have to maintain one location. The NAS syncs everything to cloud and another backup NAS. It’s easy to use, no need to keep track of what you have stored where. The initial setting-up may take some time, but so rewarding in the end. Works with BluOS flawlessly (apart from one instancenot too long ago where an update broke the credentials check, but it has been solved). It’s an investment, but a worthwhile one.
  • Brian
    Lossless
    NAS or PC or Mac will work just as well as long as it's connected to the network. I've used both Mac and NAS without issue.
