Sound cutting out while on e-arc randomly.
5 comments
    Mark
    I have had the PowerNODE for over a year and the issue just came up a couple months ago. I just switched the sound mode from AUTO to pass through on the TV side a day ago and so far haven't noticed any issues (fingers crossed).
    Thanks!
  • Bodi
    Lots of issues with Bluesound and E-ARC. I'm experiencing audio-drops on my Soundbar+ and SUB+ for 11 months now and although support is aware and able to replicate the issue, nothing has been fixed and I doubt it will ever will... I'm sure support will tell you to try different cables, reboot everything, blame your TV and whatever.
  • King Culpa
    I had a similar error with my NAD778 as well. Then I got an up-to-date HDMI cable (highest specification). Then it went with e-ARC. Is the error also with ARC (without E ?)
  • King Culpa
    specification was:
    8K Ultra High Speed HDMI Cable - 48Gbps, 8K 60Hz, 4K 120Hz,  eARC, ARC, HDCP 2.2 2.3
    Glad to hear it is working now Mark - if problems return, please select Help, Send Support Request in the App as our Support Crew and Quality Assurance team will want to see the log file of the POWRNODE. Please also include in the product description the make and model of the TV and also the content source (ie Painkillers on Netflix using an Apple TV).
    Thanks
