Qobuz with bluos 4.2.6 problems
    Hi Thomas - likely a certificate mismatch between you rpLayer and the Qobuz certificate. This can happen form time to time. On the Music Tab, select Music Services, Manage. Logo out of Qobuz. From the Home Tab, select Settings, Diagnostics and reboot your Player. Once the Player reboots and the LED is solid blue again, return to the Manage Music Services menu and log back in.
  • Thomas Zabel
    Thanks for your reply :-)
    I did perform that routine multiple times, but it did not fix the problem.
    I sent another Support Request from the app. Maybe it helps with its additional diagnostic data to reproduce the issue.
