Android - Don't override volume button when 'Output level fixed fixed'
AnsweredI'm using the app version 4.2.0 build 2837 on my android phone.
I've configured 'Output level fixed' on my player (Node). This means I can adjust the volume using my amplifier only, and not via the android app. This works ok.
The issue is that while playing music on my bluesound player, when I press volume on my phone to adjust e.g. ring volume, or media volume, I cannot do it, because the BluOS volume is adjusted. (Except it doesn't adjust because it's fixed). The BluOS app takes over the volume settings, even when the volume cannot be adjusted using the app on the phone.
Request: When the volume on the player is fixed, then don't override the volume on the phone using the BluOS app, because it only blocks other usage of the phone.
Thank you for considering
Hi Joost
Thanks for this. Our QA team is investigating. Unless you are casting via Bluetooth, the rocker buttons should not be working at all. We are investigating both potential issues.
We do hope to resolve in a near future update once we are able to replicate.
Sorry for the inconvenience.
Were you able to replicate the issue?
