Solid red indicator light
Hi Pekka
I have escalated your issue to our Support Crew. They will be in touch via e-mail to get some more details and provide options to you based on your region.
This might help you. Seems one or more capacitors on the power board have gone bad.
https://support1.bluesound.com/hc/en-us/community/posts/360048122174-NODE2-red-light-blocked
Yes. Two capacitors had broken. Since this is very typical issue in Node2, why not put it in FAQ? It took a pretty long time and many messages back and forth to get through the many steps to finally reach the local support company and their recommended electrician. The cost to replace the two bad quality broken condensators was 75 euros. Too small a sum to start any further debate. When there is a fault, it’s just responsible to admit it and give advice on how to repair it instead of referring to some older threads on the same issue.
Hi Pekka
Your Bluesound Player has no user-serviceable parts - I am pleased to hear your local distributor was there to help.
Post is closed for comments.
4 comments
