5.1 flex front
5 comments
  • Mark Crossley
    Surely an option yo have separate front left and tight Would be good.. especially gor larger rooms, to get a real left and right front stage..
  • Mark Crossley
    Thanks,
    I was looking at the blusound home theatre setup. Powernode setup for front.. would this be left , centre , right..
  • Mark Crossley
    Thanks for the link, I have already seen that page. Not really informative if I'm honest..
    I'll assume 4.1 is as good as it gets. Front left right, rear left right and sub..
    One last question.. are the rear flex 2i POE. Or do you need to factor in power outlets as well as ethernet.?
    Thanks In advance
  • Mark Crossley
    Thanks In advance
    Hi Mark
    You will require power for your PULSE FLEX 2i. Only the PULSE FLEX or POWERNODE may be used as rear speakers in a home theatre group.
    Bluesound does not have any PoE products in the residential space.
