4.0: Player group takes 5 seconds to load
AnsweredOn the new interface, when I select the player group it takes 5 secondes to appear. On the old interface this is near instant.
Since you also have issues changing source to BT (my players behave normal), it could indicate a network issue.
Have you tried breaking and recreating the group(s) if that changes anything? Rebooted network? -
On the new interface, when I select the player group it appears instantly.
How is your group configured? I have a Soundbar+, Sub+, Pulse M and Flex2i as home theater group.
Tested with all configurations. No issues.
Also, when the group appears, after 30 seconds it dissappears and the message "searching" pops up again. The group then never comes back
Edit: on iphone it works just fine.
Bjørn, I forgot to mention this is when I click the player group when I'm in the Now Playing screen. From the homescreen it loads instantly
Tested from "Now Playing", no issues.
Android 14?
Android 6-13, Windows 10
Yes, rebooted network, created group again but still issues. This particular issues seems related to Android 14. Wondering is Bluesound crew tested on Android 14 also.
10 comments
