Vault 2i Rejects Discs
AnsweredAfter +/-200 CD's, the 2 month old Vault accepts the disc, then there are multiple "clunking" sounds (as if the laser head is trying to get in position). After 20-30 seconds the disc is ejected.
This has happened with every CD recently, and all CD's play normally on a regular player. Tried a factory reset as described in the manual, but the "Play/Pause" button does not seem to light up in the manner described.
The unit has not been moved except to get the serial number off the bottom.
Best to log a support ticket, after the next disc insertion / ejection use the BluOS App and select Help…Send Support Request.
Have done that multiple times. Same fault continues. Even attached an audio file of the malfunction to an email to Bluesound support. They are running me around with a "Network Issue". This is likely mechanical, and I pais some good money for this product to crap out in less than 2 months.
Hi Dave, this a community forum so you’re best to continue working with support, I suppose if the Vault cannot access the Internet correctly then it would not return the CD’s metadata and cause issues?
I am working with them, as the lag between responses allows. I am also aware this is a community forum, and was hoping to hear from others with same or similar issues.
4 comments
