Connecting turntable to Node
Is it possible to connect your turntable to a Node other than through the Analog in port. I already use this port to connect a Bluetooth receiver for my projector.
If you have run out of inputs then the Bluesound HUB a is designed specifically for this task and even includes a very good phono stage.
