Bad sound quality
4 comments
  • Σπύρος Τζαφέρης
    I use cd input and fixed output. I will change it now to line 1. Could this make a difference?
  • Σπύρος Τζαφέρης
    Direct cd sounds definitely better than pure direct with node. But still optical+pure direct is the best combination.i changed to line 1 and i dont see things getting any better..
  • Σπύρος Τζαφέρης
    Maybe it is just that. I thought that a "better" dac should sound better. But maybe it is not always this way.. Thank you for your time!
  • Σπύρος Τζαφέρης
    Well i made several tests and i can say for sure that the problem was the cd input, i just needed some time to get used to it. I changed to line 1 input and everythink is fine as it should be. Now i like node's dac better. Thank you!
