Node + Subwoofer + Active Speakers?
AnsweredI have active Dynaudio Xeo speakers which have digital coaxial input and rca analog.
I also have active sub, which I do not use at the moment, but i would like to.
I am thinking about buying Node.
Can I connect Dynaudio via coaxial and sub via sub out? What about volume control then?
Or I have to us Node onboard dac and connect dynaudio via analog rca?
You can use the digital outputs as well as the subwoofer output, you have a option to use either fixed or variable volume with digital out, the exception being if you use MQA and it’s supported by an external DAC.
