Best connection method
13 comments
  • LD Williams
    Thanks
  • Ken
    A simple USB-SPDIF converter will give you the best result.  Don't waste your Node X.
  • LD Williams
    The node X comes with a TOSLINK Optical to 3.5mm Mini Adaptor, is this what you mean please?
  • LD Williams
    Thanks, didn't catch on to that. I'll go look for them.
    Are there any good brands to look out for?
  • Ken
    The fancy ones can be quite costly.  You may start with a $20 generic one from Amazon to try it out.
    As Seppi said, if your laptop has an optical output already, just use it.
  • LD Williams
    sadly it doesn't, it's a couple of years old but still decent.
    I don't mind costly, up to a point, as long as it does things properly
  • Brian
    Lossless
    @LD WIlliams
    I'm curious why about the use-case for playing sound from the laptop. If you are playing music files BluOS is the best choice. If for YouTube or other sources then by all means wire to the Node directly.
    Many laptops have a minijack which doubles as an optical out, most Macs have had this for decades and cables that do double duty are available on-line. You may find that your laptop does as well.
    As long as the inexpensive mini to toslink cable works it will be identical in signal to an expensive one.
  • LD Williams
    @Brian
    Netflix, Prime, Disney+, Paramount streaming, why not get as good as you can from every source.
    outs on the laptop are 3 USB A, 1 USB C, HDMI, 3,5mm,
    USB C abd 1 USB A are in use, available are HDMI, 2 X USB A, 3.5mm
  • Brian
    Lossless
    The 3.5mm may be optical.
  • LD Williams
    No way of trying right now @Brian
  • Ken
    Give HDMI a try.
  • LD Williams
    I'll give optical a try first think
  • LD Williams
    Well I got this converter and it is working just fine. Their driver seems stable for UAC2.
    So I now have USB out from laptop to optical in to the Mode X, and it sounds pretty good to me.
    SMSL PO100 Pro MQA DDC, USB to I2S Converters Support DSD512, XMOS XU316 USB Digital Interface Support PCM32Bit/768kHz, Type-C USB to IIS/Optical/Coaxial Digital-Digital Converter Support
    https://www.amazon.co.uk/dp/B0BM4D9Q9Q?psc=1&ref=ppx_yo2ov_dt_b_product_details
