Powernode Edge vs. Soundbar+ connection with LG-QNED TV
AnsweredHello,
with the Soundbar + and my two Pulse Flex 2i there were very very very many problems. Is the connection from a Powernode Edge (eARC) to the LG TV better? Has something been optimized in the hardware?
In summary, this should mean:
Are the Soundbar+ and the Powernode Edge technically identical in terms of TV sound / eARC and connected speakers?
I ask because I sell my components otherwise and prefer to switch to speakers from the TV provider
Hi Michael
Your problems are likely Wi-Fi related and will not be resolved by using a POWERNODE EDGE. The EDGE does not support being a front channel product in Home Theatre Grouping. Please select Help, Send Support Request in the BluOS App for assistance from our Support Crew.
Uuups....
my Wi-Fi is like a rocket :-) That can't be the problem! Never ever. Sure!To classify the topic better again.
I HAD the Soundbar+. But sent it back because it did not work as expected. Unlike Sonos (which worked fine). But I initially did not want to switch to Sonos, because I already have BlueSound components. But maybe I have to then to do (?)0 -
Uuups....
my Wi-Fi is like a rocket :-) That can't be the problem! Never ever. Sure!We have seen that and can help. Please go ahead and send the Support Request. What do you have to loseĀ
Thanks!
Hmmm, I don't think we understand each other. I would like to know BEFORE buying if something has been improved in the "Problematic". For example, because the technology (eARC - TV connection etc.) in the PN Edge is better than that in the Soundbar+. If that is not so, then it will again not work satisfactorily for me. Because then they could have helped me with the Soundbar+ ;-)0
4 comments
