POWERNODE 3 - No volume
AnsweredPowernode plays at an incredibly low volume. I have to hold the speakers next to my ears to hear anything.
Using Totem bookshelf speakers, banana plugs, high quality speaker wire, and no idea whats wrong.
I've done manual firmware updates, changed the speaker wires and connectors...no volume.
EDIT:
Hi Andrew,
I see you have created a support ticket with us. I'll make sure one of my support team members will reach out to you soon.
Thanks for #LivingHiFi -
Is this a new install or had it been working OK previously?
I purchased the Powernode yesterday, so this is an issue experienced on the initial set-up. Just to be sure its not an issue with the speakers or connections, I plugged everything into my NAD T748 receiver and they worked great.
So whatever the issue, its with the Powernode.0 -
You could try a factory reset but probably need to return it to your dealer.
I did the factory reset and went through a wifi and ethernet set-up for the Powernode. I continue to have the same results. I will likely return it to the dealer this week as I suspect an issue with the amplifier or connections of the unit itself.
I appreciate the replies and advice.
5 comments
