Bluesound 130 randomly goes to nearly max volume
    Hi Gary
    There is no need to factory reset your NODE. Resetting it deletes playlist and subscriptions but would not affect how volume is used other than variable or fixed in Audio Settings. The default is variable. Please download and use the BluOS App for iOS or Android for a day and remove ROON from the equation for a couple of days.
    If the issue does not occur using BluOS, please contact ROON Labs.
    If it persists or returns, please select Help, Send Support Request in the BluOS App so our Support Crew can review the event log and identify where the volume increase is coming from.
