How do I know if using AptX HD with Bluetooth headphones?
4 comments
    Hi Mark
    If your headphones use AptX-HD, then you are getting AptX-HD. BluOS Players will transmit at the highest level up to AptX-HD as negotiated by the headphones. If there was an indicator, that would be at your headphone's receive side.
  • Tamas Vilaghy
    Well, I just bought a Node X and have an ifi Go Blue which supports all codecs, including Aptx HD. Unfortunately I am getting only Aptx connection (announced by Go Blue) and there is no way to change anything on the Node X. When I stream to the NodeX, it goes via Aptx HD. Any idea how this can be fixed?
  • Mark T.
    Sr. Support Crew Member
    Hi Tamas,
    Please send us a support ticket to support@bluesound.com and a member of our support team can assist you with your issue.
    Thanks for #LivingHiFi
  • Thomas Veit
    Gibt es Neuigkeiten?
