Static noise from all sources
AnsweredHi,
This morning, when I started streaming from Spotify to the Node, there was only white noise. I tried TuneIn, same thing, LAN flacs, same thing. I don't know what happened; everything seemed good.
Restarting the unit seems to have fixed it, so no big deal for now. Anyone knows what can cause this?
Anyway, I thought I'd post it in case it happens to you. Just reboot through the Bluesound app.
Next time it happens, please send us a support ticket using the BluOS app. This way, our software will automatically send diagnostic log file/s from your player/s that will help our support team to analyze what is going on with your player.
Using the BluOS app, BluOS >> Help >> Send Support Request.
Thanks for #LivingHiFi -
Just to add, you will need to send the ticket / log before rebooting.
