Node 2 coax output bypass
AnsweredOn the older node 2, do the coax and toslink outputs bypass the built-in DAC like the newer models do. I checked the manual and it does not indicate.
Correct
All NODE and VAULT models dating back to the original NODE N100 release in 2013 bypass the onboard neutral engineered DAC when using any form of digital output.
