Cannot see Bluesound Node in sound preference.
AnsweredHi, I am not able to see the Bluesound Node in my sound preferences in order to select it as a player. I am using a Macbook pro. I am able to setup the bluetooth but would like to set it up as an airplay device to play audio from a browser with no delay. It used to be in the dropdown sound icon menu, but has since disappeared.
Any help would be greatly appreciated.
What version of MacOS are you using?
Hey thanks for the reply. I was actually able to fix it by uninstalling the BlueOS app, restarting the macbook and re-installing the app. For whatever reason is popped back up in the sound preferences as an output.
