Cannot see Bluesound Node in sound preference.
AnsweredHi, I am not able to see the Bluesound Node in my sound preferences in order to select it as a player. I am using a Macbook pro. I am able to setup the bluetooth but would like to set it up as an airplay device to play audio from a browser with no delay. It used to be in the dropdown sound icon menu, but has since disappeared.
Any help would be greatly appreciated.
Hey thanks for the reply. I was actually able to fix it by uninstalling the BlueOS app, restarting the macbook and re-installing the app. For whatever reason is popped back up in the sound preferences as an output.
