Vault ethernet connection
    Many VAULT users have used powerline ethernet kits or Wi-FI Extenders with RJ45 ports as a workaround for the VAULT's wired-only connection method. Some RJ45 ports are designed to only be used as a link to the router so it depends.
    Keep in mind, the reason the VAULT is wired only as it doubles as a NAS for other Bluesound Players in your network so requires quality upload speed as well - but is possible, if the extender allows it.
    Please check your extender documentation if the RJ45 port can be used this way.
  • Pawel Kochanowski
    Hi,
    I have one more question. I can connect via Ethernet and from SPOTIFY music from my phone can be played. However when I'm trying to connect to you Blue sound App my phone don't see it. Same thing when I'm trying to use Tidal. How can I 'find' my device
