Using Spotify on NAD M10 album art not showing - display is "dark"
AnsweredAttempting to play Spotify feed through NAD M10 and audio plays but the display goes "dark" after a few seconds. Sometimes nothing displays on the screen, not even for a couple of seconds, but the audio does play. This has worked flawlessly in the past - I would see the album art, volume settings, as usual. Is this due to the recent hardware update?
Thanks for any help you might provide in remedying this problem.
Rob
Hello Rob,
I've got Spotify Album art showing up on my M10 here normally. Could be possible that you have Settings (via front panel) > Player > LCD Temporary Display set to ON.
Hey Sam, thanks for your response and suggestion, it worked! I have no idea how the setting got turned off -I'm the only one who uses the system so chalk it up to user-error I guess?
Thanks again, greatly appreciated!
Rob
