Audio clipping all sources
    Hi Thomas
    Help, Diagnostics in the BluOS App and check your signal strength. Sounds like classic throughput issues due to poor signal strength. Check our network troubleshooting guide at www.bluesound.com/network101 or select Help, Send Support Request in the App for us to take a closer look.
  • Brian
    Lossless
    I sympathize, when Bluesound doesn't work it can be extremely aggravating. I've often wanted to throw one of my original Pulse's out the window.
    I have one unit, a C368, wired using a Powerline ethernet adapter which works well, no dropouts at all.
    I am puzzled that you report dropouts from the TV optical input as this is a wired connection and has nothing to do with wireless. In that case there may be some issue with your hardware – if it's under warranty get it replaced.
