Connect Vault 2i to Lumin U1 Mini
4 comments
    Bjørn Ulvik
    Your Lumin needs UPnP enabled at the "source". Your Vault don't have that option.
  • Joerg Ue
    Thanks, however UPnP is enabled in the Lumin settings.
    I have a WD NAS in parallel (to be replaced with the Vault) which is showing up without issues in Lumin.
    Hi Joerg
    Bluesound Players do not support UPnP. They only support Windows File Sharing through SMB.
  • Joerg Ue
    Thanks Tony, clear, I will hence return the device, I should have been more careful reading what the real capabilities are re Media Server and NAS
