Bluesound Node 2i - Optical input from TV not selectable
    Hi Shahram
    Sounds like a bad connection - please check or even replace the optical cable. If problems persist, please select Help, Send Support Request so we may see the log file if the cable is being detected at all.
  • Shahram Baradaran
    I will try getting a new cable and see what happens.
    Shahram
