Output Mode on Vault2i
5 comments
  • Bjørn Ulvik
    If you, after making changes, "restart" what's playing it works.
  • planapo63
    Thanks, I will try that and let you know - on a similar note I also have the BlueOS on my MSWin8 32bit computer on same network as BlueOS and if I go into the Windows app when I go to "Audio" I can see "output" shows 4 choices "stereo" "Left" "Right" and "Mono" but all are unchecked and if I click mouse over one it will show "blue" while mouse button is held down but when I release it goes away? Version on Win8 32bit is 3.4.5 is there a newer version that fixes this?
  • planapo63
    Your solution only seems to work on the Vault2i for CD's that were ripped into the library for Tidal and TuneIn has no effect at all.
    Scott
  • Bjørn Ulvik
    Hi Scott,
    What source you use don't matter since it's the "output" you are altering.
    Find a "left/right speaker test track" in Tidal, play the track, make any changes, use the "previous" button, and you will notice the change.
    Left or right will be played in both output channels so it's not "easy" to hear if you are using a music track rather than a dedicated "test track"
  • Sam R.
    Output Mode is designed to not affect MQA files as a requirement of MQA implementation which may be what you're seeing in TIDAL.
    TuneIN however may come down to the stream itself being binaural symmetry.
