Vault2 repeatedly goes into "Looking for Network Shares" mode (flashing green light).
    Avatar
    A flashing green led suggests your Vault is not connected to the network. Please check or replace your network cable.
    Comment actions Permalink
  • Avatar
    Tom Garvey
    Based on your response, I moved the Orbi satellite that the vault is plugged into to improve its connection to the Orbi wifi router, and that seems to have solved the problem.
    The owner's manual only IDs the flashing green light as an indication that it's looking for network shares.  It would be useful and would have saved time to add to the knowledge base that the flashing green light can also indicate a weak network connection.
    Thanks,
    Tom
