General Bass volume has no effect when external sub is connected
    This is by design Lasse
    You will want to turn the volume up on the SUB to achieve what it sounds like you are looking for as the SUB is an independent player.
  • Lasse
    Thanks it makes sense. Ideally, it would make sense to make the slider inactive then, since it has no effect, when an external sub is connected ?
    Thanks for the feedback, but inversely you may want lower tones that are above the crossover boosted. You cannot do that otherwise. The implemented solution is actually the most correct one for making fine adjustments in the lower end.
