DAC problems, serious ones!
    Hi George
    Thank you for your feedback. By design, Bluesound DACs are neutral. We concentrate on the direct reproduction of sound as recorded. That may not be for everyone, why you have the ability to bypass the onboard DAC via optical or COAX.
    Not sure why you would upgrade via USB stick - there is no advantage to doing it this way. There is also no change to the firmware based on how you upgrade
    MQA Bypass is disabled because you enabled tone controls. Tone controls are not allowed by MQA compliance. Please see www.mqa.co.uk for more details.
