Airplay+Bluetooth not as loud as tidal(connect)
5 comments
    HI Lasse
    Correct! What you are hearing is one of the many audio quality differences of lossless audio.
  • Lasse
    Thanks. As i thought. :)
  • Lasse
    Actually. I still kinda wonder about this. Volume of another BT speaker (different brand), is similar high in volume on tidal, on BT, without tidal connect.
  • Dave Chawner
    Hi Lasse, audio quality has nothing to do with audio level !
    I notice the same issue with my Powernodes in that some sources play at noticeably different levels for a given volume setting. Unfortunately Bluesound products don't seem to have audio source trim adjustments so you can balance the relative audio levels across the various sources.
  • Lasse
    I see.  Its kinda sad that the normal volume, when using airplay to the soundbar is so low, compared to when playing through tidal-connect.
    Especially taking into considerations, when using BT on the other branded speaker (much cheaper cost wise), the volume level matches the bluesound soundbar when using tidal-connect as the source...
