Node 2i Audio Settings
6 comments
    Avatar
    Hi Redmoid
    Please ensure your Player is connected to the Network. Here's how www.bluesound.com/setup.
    If it is connected, check and ensure your home network router has Multicast enabled.
    Comment actions Permalink
  • Avatar
    Redmoid
    The Node 2i is working fine on the Network, streaming songs from my hard drive and from Spotify.  The problem is that I cannot access "Audio" under Settings.
  • Avatar
    Please check your router to see if it is blocking network traffic by not supporting Multicast
  • Avatar
    Redmoid
    Multicast is enabled.  The only thing not working is getting to the AUDIO menu under SETTINGS/PLAYER.
  • Avatar
    Redmoid
    I'm still waiting for a response.  What is the reason I cannot access the AUDIO menu?
  • Avatar
    HI Redmoid
    Please select Help, Send Support Request in the App so our Support Crew may take a closer look by reviewing the system log attached to that request.
